Activity Forums Apple Final Cut Pro Legacy Mixing HDV & SD to make a SD DVD both PAL & NTSC
  • Mixing HDV & SD to make a SD DVD both PAL & NTSC
    Posted by Brendan Pyatt on April 24, 2009 at 4:11 pm
    Working on a project that mixes HDV, SD Pal and SD NTSC footage that will end up being a DVD to be released in both PAL & NTSC formats.
    I would like to use Apple Prores as the working codec as I understand its high quality and seems to work when sending to and from Apple Color.
    I am not 100% certain what used to shoot the footage but examining the clips using MediaInfo tells me that I have two types of clips:
    1440×1080 29.97fps
    720×480 29.97fps
    I don’t have the option of recapturing I just have to make the best from what I have.
    I am really confused about what sequence settings to use! Ideally i would like to make a widescreen DVD.
    Please help!! Thanks.
    Brendan Pyatt replied 17 years, 4 months ago 1 Member · 2 Replies
  • Brendan Pyatt
    April 24, 2009 at 5:08 pm
    From different posts etc I believe I need to run the 1440×1080 clips through compressor.
    So I guess my main issue is what should I set my timeline sequence settings to?
    In FCP i can see:
    Apple ProRes 422 NTSC 48 kHz
    but also
    DV NTSC 48 Anamorphic
    but no Apple ProRes 422 NTSC 48 kHz Anamorphic…which what I think I need.
    Once I know what sequence settings to use I can then compress the 1440×1080 clips to the same settings..
  • Brendan Pyatt
    April 24, 2009 at 7:52 pm
    mmm confused.
    I just can’t get the 1440×1080 clips out of Compressor using Prores codec to be 16×9!
    What ever i set in Geometry seems to have no effect.
