Mixing GoPro Hero 3 Black Protune 2.7k cine 24fps with 5D MkIII 1080p 24fps
As the title so technically states, I am shooting projects mixing GoPro 2.7k with 5D 1080p. Shooting in 2.7k for the added resolution for downscaling to 1080p. I am using FCP7 by the way.
I have tried to research best practices for this post process and haven’t been able to cobble together the info I’ve found and apply it to what I’m doing.
My attempts so far have been:
1) Convert the 2.7k protune camraw footage in GoPro studio, but the exported 1080 CFHD codec video doesn’t seem to work with my FCP timeline conformed to my 1080p ProRes 422 5D footage. Compressor would not allow me to convert the CFHD to ProRes (maybe try MPEG Streamclip?). I have seen that quicktime has a difficult time with CFHD in some cases?
2) Put the raw GoPro file into compressor and export a 1080p 422 ProRes file. The file seems to play choppy, however, and the original file seems much smoother. I am using a fast enough micro SD to record the 2.7k footage, I don’t seem to have dropped frames and it records unhindered, and I’m running a recently purchased trashcan mac pro (highest model).
THAT SAID, I have a few questions:
– Does the protune GoPro footage need to be corrected or processed before editing, or can I edit the protune footage and color correct after the fact?
– Is FCP7 too much of a dinosaur to correctly address this kind of workflow I’m attempting?Thanks for any input and I apologize for the exhausting post.
Dean Fisher
