Activity Forums Adobe Premiere Pro Mixing Frame Rates and Creating Old Film Look?
  • Mixing Frame Rates and Creating Old Film Look?
    Posted by Dom Fisher on November 1, 2013 at 10:08 am
    Hello, I’m working with AVCHD footage which is 59.94 fps and have made my sequence settings at this frame rate. I’ve dragged in a few clips 23.98fps, 24fps, 25fps and 29.97fps, I’m attempting to give it a old film look so was going to render out at 14 fps as this is what 8mm is filmed at, I’ve never worked with mixed rates so any advice as to whether this is going to work? Should I have my sequence setting at my highest frame rate and the majority of the video is 59.94fps? would it work exporting at 14 or 16 fps?
    Chris Gunningham replied 12 years, 10 months ago 2 Members · 1 Reply
  • Chris Gunningham
    November 1, 2013 at 4:10 pm
    Keep it all 59.94 interpreting your off speed footage to 59.94 will make it the correct speed without duplicate or skipped frames, I would then use the posterize time effect to force to 14fps in premiere.
    Chris Gunningham
    Online/VFX Editor
    Any opinions expressed are solely my own.
