Activity Forums Sony Cameras Mixing formats in FCP 7 & image stuttering / jaggies
  • Mixing formats in FCP 7 & image stuttering / jaggies
    Posted by Charla Barker on January 7, 2010 at 7:10 pm
    Hi all,
    I’m editing a project in FCP 7.0 that has several different kinds of footage. Some of the footage was shot with a Sony EX3 – shot at 1080p30 35 Mb/s VBR 1920×1080. There is also footage that is DVCPRO 50 (720×480). And also some that is Apple ProRes 422 (HQ) 1920 x 1080. And I’ve noticed that in my sequence the DVCPRO 50 footage has a “stuttering” effect – meaning that the footage has jaggies / pixelation. But if I put that same footage on a sequence that has settings matching the footage there’s no problem and it looks great. So I’m wondering what I can do to get rid of the jaggies / pixilation that’s occurring. I’m guessing that it has to do with the sequence settings so I put info on that below:
    FCP sequence settings:
    Frame Size: 1920 x 1080
    Aspect Ratio: HDTV 1080i (16:9)
    Pixel Aspect Ratio: Square
    Editing Timebase: 29.97
    Quicktime Video Settings:
    Compressor: Apple ProRes 422 (HQ)
    Quality: 100%
    Under the Render Control tab the codec is set to AppleProRes 422
    System Info:
    Desktop
    Mac OS X 10.5.8
    Processor 2 x 2.8 GHz Quad-Core Intel Xeon
    Memory 8 GB 800 MHz DDR2 FB-DIMM
    FCP: 7.0
    Quicktime 7.6.4
    Sincerely,
    Charla Barker
    Charla Barker
    Charla Barker replied 16 years, 8 months ago 2 Members · 3 Replies
  • Clint Fleckenstein
    January 7, 2010 at 7:50 pm
    Make sure that FCP is rendering the whole sequence then, since some clips don’t match your sequence codec. Just hitting Apple-R doesn’t do that unless you change your application settings. Under Sequence>Render All I believe you can force that. Otherwise I think it’s trying to do it on the fly.
    Cf
  • Charla Barker
    January 7, 2010 at 8:02 pm
    Definitely – I’ve been rendering the whole sequence by clicking “Render All” and I have all the options on the right of that menu clicked on (Needs Render, Rendered Proxy, Proxy Preview, Full, Unlimited) so it should be getting everything. But I still have the jaggies/pixelation.
    One other thing I just thought of is that the DVCPRO 50 footage is anamorphic. And the Sony EX3 footage isn’t. I wonder if that could cause the issue?
    Charla
    Charla Barker
  • Charla Barker
    January 7, 2010 at 10:15 pm
    I may have found a solution. I changed the Field Dominance in the Sequence settings so it matches the DVCPRO 50 footage – field dominance for that footage is read as “lower field” first in FCP. And by doing that it does greatly reduce the jaggies / pixelation. It doesn’t eliminate them completely but it does help a lot.
    Charla Barker
