Activity › Forums › Avid Media Composer › Mixing footage in the same sequence
  • Mixing footage in the same sequence
    Posted by Rui Coutinho on January 13, 2010 at 4:54 pm
    Hi !!
    I have material from Sony EX3 and from RED on 2K.
    Does it is possible to mix those two formats in the same sequence in Avid Media Composer 3.5 ??
    And in the version 4.0 its possible ??
    Thanks !!
    Job Ter burg replied 16 years, 8 months ago 2 Members · 3 Replies
  • Job Ter burg
    January 13, 2010 at 7:39 pm
    Only in v4. The EX is likely 23.98p-within-60i. The Red can be 23.98p, 24.00p or 25.00p.
  • Rui Coutinho
    January 14, 2010 at 11:39 am
    Thanks!!
    And about the resolution, since I got two diferent resolutions 1080×1920 and 2K,
    my final resolution will be 1080×1920, cause I cant go further in the EX-3 material..
    Its correct??
    Thanks!!
  • Job Ter burg
    January 14, 2010 at 10:35 pm
    Avid will only do Rec709 HD video in 1920×1080. So you can’t do full 2K, and you cannot work in RedSpace. To get the Red footage in, you need to convert it to DNxHD. You can use MetaFuze for that, or RocketCine-X or RedCine-X or RedRushes, or Scratch or Baselight/BLT, and perhaps some more. MetaFuze is available from Avid at no charge (new version, 2.1): https://www.avid.com/metafuze.
