Activity › Forums › Apple Final Cut Pro Legacy › Mixing DVCPro HD and some kind of SD
  • Mixing DVCPro HD and some kind of SD
    Posted by Göran Thorén on August 13, 2009 at 12:57 pm
    Hi all!
    OK, here is my scenario:
    I have recieved a bunch of materail shot in DVCPro HD. The final result is going to be in SD.
    I´m creating an intro in After Effects shot with SD wich is going to be included in the final film.
    So, which is the best workflow for this? I would like to be able to view the intro together with the DVCPro HD edit and then somehow convert the HD material to SD when the edit is locked.
    What is the recomended format going from DVCPro HD (which is 1440×1080) to SD?
    Should I render the SD intro in 10bit uncompressedand downconvert the HD to that also?
    Thank´s
    Göran
    Göran Thorén replied 17 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
