Activity Forums Apple Final Cut Pro Legacy mixing DV and IMX material
  • mixing DV and IMX material
    Posted by Samir Kassab on July 14, 2010 at 11:39 pm
    hey guys
    I’m working on mixed sequences all the time & i am having a trouble when speeding a clip in a mixed sequence of DV and IMX materials!
    see,if i speed a clip which has the same properties of the sequence it speeds up ok,but if i speed up a clip that has a different properties other of these the sequence (i’m talking dv and beta IMX in here) it gives me a very annoying jitter effect that refuse to get smoothed even if i use the blending effect or if i check the smooth motion box in the motion tab….
    so if any of you guys has a solution or a hint , it would be great!thanks
    Samir Kassab replied 16 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
