Activity Forums DSLR Video Mixing Canon 5D 1920x1080p with Z1 1440x1080i footage on same timeline – is it possible?
  • Mixing Canon 5D 1920x1080p with Z1 1440x1080i footage on same timeline – is it possible?
    Posted by Harjite Dosanjh on February 10, 2013 at 12:25 pm
    Hi Guys,
    Need some advice with the following issue.
    I have footage captured form a Sony Z1 and from a Canon 5D MKII. My Sony footage is 1440x1080i and my Canon footage is 1920x1080p.
    Im using Premiere Pro CS5.5 for editing.
    When I export the footage and burn with Encore I am have field issues. I have tried many things to remove this issue but nothing is working? I have tried to change the 1080p footage to upper field but no luck.
    Has anyone ever work with these different element and managed to burn a blu ray without any field issues?? If so pleas could you share how you did so?
    Many thanks in advance!
    Harjit Dosanjh
    H
    Minu T a replied 12 years ago 3 Members · 4 Replies
  • Harjite Dosanjh
    February 11, 2013 at 2:12 pm
    Hey Bob,
    Thanks for your response mate. Ill give it a go and see how I get on!
    H
  • Harjite Dosanjh
    February 11, 2013 at 2:19 pm
    Quick question, in PP which sequence setting would you use? DSLR 1080p25 or HDV 1080i25 (50i)?
    Many thanks!
    Harjit
  • Harjite Dosanjh
    February 12, 2013 at 11:48 pm
    Thanks again Bob! Appreciate the advice!
  • Minu T a
    August 26, 2014 at 8:55 pm
    the reply post seems to be removed..i too have the same issue matching 5D with Z1.which sequence setting would you use? DSLR 1080p25 or HDV 1080i25 (50i)? i would also like to know if the same is possible in FCP
