Activity › Forums › Apple Final Cut Pro Legacy › Mixing 720p60 and 720p24 on a timeline
  • Mixing 720p60 and 720p24 on a timeline
    Posted by Jeremy Edney on January 6, 2010 at 8:59 pm
    All,
    I have some DVCPRO HD footage captured at 720p60 and some captured at 720p24. Can I mix these on the same timeline and if so, what’s the best way to go about it? Should I digitize the 60 at 24 or vice versa? Neither? Throw it on the timeline and roll with it? A 60 timeline or a 24 timeline?
    Help!
    Bonesaw
    Jeremy Belzer-adams replied 16 years, 8 months ago 3 Members · 5 Replies
  • Shane Ross
    January 6, 2010 at 9:05 pm
    What do you have more of? What is your delivery requirement in terms of frame rate? I have had good luck with 720p60 on a 720p24 (DVCPRO HD) timeline with the use of the Nattress Standards Converter. But my delivery was a 23.98 master. 23.98 to 60… That won’t look right. You’ll have to use Compressor to convert that properly…
    Shane
  • Jeremy Edney
    January 6, 2010 at 9:12 pm
    My final delivery is web (so that’s 30 right) but there is a chance it is moved to our network and that’s 60i right? The issue is that my producer wants the 24 look but didn’t tell the first crew that information so now I have both!
    cheers,
    j
    Bonesaw
  • Shane Ross
    January 6, 2010 at 9:46 pm
    [Jeremy Edney] “My final delivery is web (so that’s 30 right)”
    Web is anything from like 10fps to 60fps. Whatever you encode to. Less FPS means smaller file, so people at times go small. 24fps would be the way I’d go here then.
    [Jeremy Edney] “ut there is a chance it is moved to our network and that’s 60i right? “
    That’s 29.97fps… 60i means INTERLACED, but you can output progressive too. As long as you have a capture card (AJA, DECKLINK, MATROX) then it will add the proper pulldown from 23.98 to get you to good 29.97.
    [Jeremy Edney] “The issue is that my producer wants the 24 look but didn’t tell the first crew that information so now I have both! “
    Fire them. Or scold them. Wait, they hire you. Gently remind them that information like that is VITAL to successful post production.
    Shane
  • Jeremy Edney
    January 6, 2010 at 10:10 pm
    Wait a sec… forgive my ignorance but you’re saying HD broadcast is running at 29.97?
    Bonesaw
  • Jeremy Belzer-adams
    January 7, 2010 at 6:52 pm
    HD Broadcast runs at 60i, or 60 interlaced fields per second. In terms of FPS, it is 29.97.
