Activity Forums Apple Final Cut Pro Legacy Mixing 24P and non 24P in a sequence & Real Viz retimer
  • Mixing 24P and non 24P in a sequence & Real Viz retimer
    Posted by Neobe Velis on June 27, 2006 at 6:43 pm
    Hello,
    I’m pulling in some footage from a music video. The A Cam was a DVX100 shooting 24P (not PA) and the B Cam is a Sony that did not have 24P. I am used to working with the DVX100 footage but wanted to check if there is anything I need to do differently.
    Also – have you heard of Real Viz Retimer? It is supposed to be a filter I can use for better slomo but wanted to see if anyone has used it.
    Neobe
    Shane Ross replied 20 years, 2 months ago 2 Members · 1 Reply
  • Shane Ross
    June 27, 2006 at 7:05 pm
    Just capture both tapes as DV/NTSC. They won’t match in terms of their look, but if you want the Sony footage to better match, all you need is the Film Effects plugin from http://www.nattress.com.
    No clue what that other thing is.
    Shane
    Shane
    Alokut Productions
    http://www.lfhd.net
