Mixing 24fps and 25fps on the timeline
Briefly, I’m editing a live music video, where one camera was operating at 24fps PAL (covering the drummer) while the rest were at 25fps PAL. Reason was, the rogue camera did not have the option for 25fps – video shot in US, but for UK market here. Shot on DSLRs, when converting to Pro Res, I did not change the frame rate of the drum footage, as I felt the sync might drift. I’ve edited with this footage mixed in and all looks fine.
However, my question is – when I output, will there be a problem – either in how it outputs with a mix of fps, or in the way the film looks?
By conforming from 24 to 25 fps in Cinema Tools, or initially during conversion with Magic Bullet Grinder, I was concerned that messing with the frame rate might put me in a world of pain with regard to sync – drums have to be on the spot with every beat. I’d value m’ learned friends opinions here, and apologies if this is an obvious query – I’m a bit of a newbie on the technical side, so be gentle with me!
Regards
Graham
