Activity Forums Apple Final Cut Pro Legacy mixing 2 videos (slightly diff specs) together in FCP7 timeline
  • mixing 2 videos (slightly diff specs) together in FCP7 timeline
    Posted by Raju Bhai on December 27, 2014 at 3:19 pm
    Hi, the 2 videos I have are almost the exact same specs. But there is only a slight differnece, the first video is QuickTime and the second video has dot AVI extension in file name. i am wondering if they will work together in the same FCP7 sequence.
    Video 1 (already edited in timeline):
    DV 720×576 (768×576 actual), millions
    16-bit integer (Big Endian), stereo, 48 khz
    25 fps
    data rate: 30.34 Mbit/s
    Video 2 (i just received this and will cut it into the timeline with Video 1):
    A-Law 2:1, stereo, 48 khz
    25 fps
    data rate: 29.67 Mbit/s
    OK please let me know if i have to transcode Video 2 to use it in Video 1’s sequence or if i’ll be fine without transcoding Video 2.
    thank you
    Raju Bhai replied 11 years, 8 months ago 2 Members · 4 Replies
  • Shane Ross
    December 27, 2014 at 4:11 pm
    QUicktime and AVI are containers…that’s the only difference. FCP doesn’t work with AVI, so you need to use Compressor to convert it to DV/PAL. BOTH videos should be converted to that format, as FCP doesn’t just work with any QT format…it needs to be in an FCP editing codec. DV/PAL is one.
    Shane
    Little Frog Post
  • Raju Bhai
    December 27, 2014 at 4:23 pm
    I already edited Video 1 (the one i said is a Quicktime movie) in FCP7 without converting it first. The reason I called it a Quicktime movie is because that’s what it says under file “Kind” in the Apple finder. Anyway, FCP7 already recognized it as a DV/PAL format. So i take it, i should only need to convert the AVI clip then?
  • Shane Ross
    December 28, 2014 at 7:00 am
    Correct. Just convert the AVI
    Shane
    Little Frog Post
  • Raju Bhai
    December 28, 2014 at 8:08 am
    OK thanks Shane!
    Just curious, if AVI is nothing more that a container and the ATV clip already has the exact same DV PAL settings as the quicktime clip, then what’s the need to transcode?
