Activity Forums Apple Final Cut Pro Legacy mixing 16×9 and 4×3 footage on same timeline
  • mixing 16×9 and 4×3 footage on same timeline
    Posted by Falk Eggert on March 25, 2010 at 7:10 pm
    I have to edit footage from 2 cameras shot in dv Pal onto the same timeline. The broadcast is 4X3.
    The problem is that one camera was shot 16X9 and one 4X3.
    How do I get the 16X9 footage to be edge cropped? So that it will work with the footage from the other camera.
    I have tried running it through compressor, and changing the geometry tab to 4X3, but I end up with a squashed image.
    Anyone know a simple fix?
    Your help would be appreciated
    Don Greening replied 16 years, 5 months ago 2 Members · 1 Reply
  • Don Greening
    March 25, 2010 at 7:20 pm
    Create your 4:3 sequence and drag your first 16:9 clip into it. FCP will automatically letterbox the clip. Double-click the clip to load it into the viewer. Click on the scale parameter tab in the viewer and scale the clip to 100%. In the canvas window now you’ll see the clip filling the frame but the sides are cut off. You can also accomplish the same thing in the canvas window by dragging a corner of the clip until the top and bottom fill the frame. Anyway, after you’ve scaled up the first 16:9 clip in the viewer just hit “Cmd – C” to copy that clip’s attributes to the clipboard. Drag the rest of your widescreen clips into the timeline, highlight them all and the hit “Option -V” to paste the first clip’s attributes on to all the other 16:9 clips. All your 16:9 clips are now centre punched to fit the 4:3 sequence. Go for coffee.
    – Don
