Activity Forums Apple Final Cut Pro Legacy mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
  • mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
    Posted by Per Olsson on November 16, 2010 at 2:06 pm
    Hi!
    I have two clips.
    clip 1:
    1440 x 1080
    25 fps
    clip 2:
    1280 x 720
    29,97 fps
    My final export shall be in:
    1440 x 1080
    25 fps
    final cut doesnt seem to react when im mixing these two formats in the timeline. but how do this affect my movie? or final cut handles these two without any problems?
    thanks
    Perik
    Shane Ross replied 15 years, 10 months ago 2 Members · 3 Replies
  • Shane Ross
    November 16, 2010 at 2:39 pm
    Look closely at the 29.97 footage in the 25fps sequence. Does it look odd and steppy to you? If not, then work away. But if so, then you need do convert it before you edit…with Compressor.
    The cadence won’t be smooth if you leave it as is, but if you can’t see anything you don’t like, then work with it that way. If this was for broadcast, they might kick it back because of the cadence issue.
    Shane
  • Per Olsson
    November 16, 2010 at 3:23 pm
    ok, thanks.
    if I shall bring it to compressor, what settings do I want to have there?
  • Shane Ross
    November 16, 2010 at 6:19 pm
    Choose the setting you want, in the ADVANCED CONVERSION section. THen in the Inspector, turn on the FRAME CONTROLS and set them all to BEST.
    Shane
