Activity Forums Media 100 Mixing 1080p/23.98 & 1080i/29.97 clips in the timeline
  • Mixing 1080p/23.98 & 1080i/29.97 clips in the timeline
    Posted by Joseph Stillman on June 20, 2012 at 11:36 pm
    I’ve shot 90% of a project @1080p/24fps and need to add 1080i/29.97 clips to the timeline but i’m not able to do it. I have the latest version of M100 suite. I’ve imported those 1080i clips but they don’t conform because the frame rate is different. What do I need to do to make them work. I want to mix other q-times clips too but anm having the same problem.
    Joseph Stillman replied 14 years, 2 months ago 2 Members · 5 Replies
  • Fermin Branger
    June 25, 2012 at 3:23 pm
    You have to convert all 1080i29.97 media to 23.98, pulling up all clips using AE or other app like DVFILM-MAKER, before import it from M100.
    You could perform a ‘force’ import to standard and codec from M100 (selecting it in the import window), but it isn’t a clean interpretation of the movement, because it do not pull the cadence of the frames.
    What are your camera/codec settings?
    Are you working at 23.98 or 24 fps?
    Fermin Branger
    ALFARERIA CINEMATOGRAFICA
    Caracas, Venezuela.
    http://www.alfareriacine.com
  • Fermin Branger
    June 25, 2012 at 3:31 pm
    Fermin Branger
    Caracas, Venezuela.
  • Joseph Stillman
    June 26, 2012 at 1:46 pm
    I’m shooting w/ a Panasonic AF 100, set for 1080p/24f. My Media 100 program timeline, which is set for 1080fps/23.98 works great w/ all the footage I’ve shot at that setting. Its just it won’t integrate 1080i/60 foot. I’ve converted that 1080i footsage using Wondershare to 1080p/23.98 but it still won’t take it. I’ve got numerous other assets to import but the M-100 conform function tool doesn’t change the frame rate. What am I doing wrong? Thanks, Joe
  • Fermin Branger
    June 26, 2012 at 2:42 pm
    That’s a great camera, we’re shooting a 13 chapters documentary series for TV with that camera right now, and we’re converting all 1080i60 material that we receive from different sources, using MAKER from Marcus van Babel from DVFILM. It has around 10 years since he created it, and is still working great in it’s last versions. You can convert 1080i60 clips to 1080P23.98 using the codec of your choice: uncomp_10, PRoResHQ…
    I don’t know Wondershare but I can assure that with Maker you can do the job.
    https://dvfilm.com/maker/macversion.htm
    Fermin Branger
    Caracas, Venezuela.
  • Joseph Stillman
    June 28, 2012 at 5:48 am
    Thanks, Fermin… I’ll try that! Best, Joe
