Activity Forums Apple Final Cut Pro Legacy Mixed SD and HD footage – what to do?
  • Mixed SD and HD footage – what to do?
    Posted by Niklas Wikman on December 28, 2015 at 5:52 pm
    9 mins long, 7 mins is DV50 PAL, 1024×576.
    The rest is 720P50
    If I place the HD footage on the SD timeline, it scales down just fine. But I do get moving artifacs, or rather a sense of “film”. I guess thus is because of the default frame rate.
    Is there anythin I can do to make the HD footage “mix” better with the SD footage? You also see the effect in dissolves between the HD and SD footage.
    Nick Meyers replied 10 years, 8 months ago 3 Members · 9 Replies
  • 9 Replies
  • Shane Ross
    December 28, 2015 at 7:11 pm
    [Niklas Wikman] “DV50 PAL, 1024×576.”
    How is your SD footage this dimension? That isn’t the normal dimensions for PAL SD. 720×576 is.
    Shane
    Little Frog Post
  • Niklas Wikman
    December 28, 2015 at 7:35 pm
    Of course it is 720×576. But since it is widescreen, the ref movie plays at 1024×576.
    I guess the best thing would be to use either Episode 6 or perhaps Compressor and transcode the 720P50 footage to SD….?
  • Niklas Wikman
    December 29, 2015 at 5:42 am
    Oh, sorry!
    It will most likely end up on the web.
    The reason for the mixed footage is that some of the parts was taken from another project, when we had made the shift from SD to HD.
  • Shane Ross
    December 29, 2015 at 9:36 pm
    I wish I knew what you were describing. Because I can’t picture it. Some sort of artifacting is happening. I wonder if it has to do with the pixel dimensions of both formats.
    Shane
    Little Frog Post
  • Niklas Wikman
    December 29, 2015 at 10:35 pm
    Yes, SD is interlaced. And is 90 percent of the film.
    Hence the question if anything can be done with the HD footage (which is progressive).
  • Shane Ross
    December 29, 2015 at 10:37 pm
    If this is going to end up on the web, then you want to deinterlace the SD footage. The web doesn’t display interlacing properly, only TVs do.
    Shane
    Little Frog Post
  • Niklas Wikman
    December 29, 2015 at 10:51 pm
    Dang…
    I was hoping you would suggest the other way around…
    So, what’s the best eay to go? Compressor? Episode?
    I hope I can use the final film – or are we talking about de-interlace every single footage file here?
  • Niklas Wikman
    December 30, 2015 at 12:05 am
    *sighs and shrugs*
    Thanks Dave and Shane – you had me there.
    This will be a totally new thing for me – but I guess I will have to find the best app for the job, place all the transcoded clips in a separate folder (with the original names and a suffix) and then start re-linking… Manually, I guess.
    But thme main thing remains – what tool to use?
  • Nick Meyers
    December 30, 2015 at 2:22 am
    “But I do get moving artifacs, or rather a sense of “film”. I guess thus is because of the default frame rate.”
    could be you haven’t rendered it yet.
    remember to go to your sequnce’s settings, video tab, and set Motion to “Best”
    get the Nattress plugin, it. works in FCP.
    nest your sequence, by dragging it from the browser into a new sequence with the same settings,
    and apply the filter to the nest
    nick
