Activity Forums Apple Final Cut Pro Legacy Mixed Media in SD timeline HELP
  • Mixed Media in SD timeline HELP
    Posted by Ben Chappell on October 25, 2007 at 4:34 pm
    We are cutting some spots that will finish DigiBeta for Broadcast. Some 720p footage, 1080p footage, and some 35mm film transfered to DigiBeta.
    Since its finishing SD we’re cutting in a Uncompressed 10bit Timeline. Why is it, that when I bring in a 720p clip for example, i don’t get the full resolution of the clip? If the motion tab is at 100% it should be much larger than my 720×486 sequence….right? We’d like to repo some of these shots, and also put small pans across the HD footage, but i have to go above 100% to do this, and i’m losing resolution.
    If I do the exact same thing in an After Effects comp, it acts as it should…the HD footage is 1280×720 and clearly larger than the 720×486 comp. Thus far, i’ve been bringing these clips into AE….but I’d rather stay in FCP for it all.
    Should i be cutting in a difference Sequence?? Any help is appreciated. Thanks.
    Ben
    David Jahns replied 18 years, 11 months ago 2 Members · 2 Replies
  • David Jahns
    October 25, 2007 at 6:55 pm
    Yes, if you’re Motion tab scaling is at 100%, it should be quite a bit larger than your SD sequence. A quick way to do that is to highlight the clip in the timeline and REMOVE ATTRIBUTES – Basic Motion.
    Can you look at it in wireframe mode to double check? Also set your canvas view to 50% or so to see the oversized media in relation to the smaller canvas size.
    The lack of resolution you are seeing in an SD timeline is a much more complicated issue. There’s a rather lengthy thread where we dug into this pretty deep – and Jeremy G has just today posted a solution, we think. But read it from the top to get the full story on what is going on and why…
  • David Jahns
    October 25, 2007 at 6:56 pm
    sorry – forgot to link to the thread.
    https://forums.creativecow.net/thread/8/958052
