Activity › Forums › Apple Final Cut Pro Legacy › Mixed media footage with jagged edges
  • Mixed media footage with jagged edges
    Posted by Leeor Tal on July 8, 2013 at 8:55 pm
    i have 5 different footage sources (all PAL and all SD- most 720×576) and some of them might need deinterlacing because i can see jagged edges in the sequence.
    the final output will be shown via computer on a movie projector.
    i’m not sure what would be the best sequence setting and how best to export it. also, i’m not sure how to tell if something needs to be deinterlaced inside of the sequence before export.
    i tried sending the sequence to color and rendering it out as ProRes 422 but i still see jagged edges on some of the clips.
    what to do?
    Shane Ross replied 13 years, 2 months ago 2 Members · 3 Replies
  • Shane Ross
    July 8, 2013 at 9:23 pm
    Deinterlace. or set the sequence settings to FIELD ORDER:NONE. Interlacing looks fine on TVs, but not on computer monitors. Video projectors…maybe. Some people use them as TVs.
    Shane
    Little Frog Post
  • Leeor Tal
    July 9, 2013 at 9:47 am
    Thanks for the quick response.
    Should I deinterlace only the clips where I spot the jagged edges or deinterlace the whole sequence when I export it?
  • Shane Ross
    July 9, 2013 at 4:34 pm
    All of them. It’s easier to make the sequence have NONE for Field Order.
    Shane
    Little Frog Post
