Activity › Forums › Apple Final Cut Pro Legacy › Mixed Frame Sizes within the Same Project
  • Mixed Frame Sizes within the Same Project
    Posted by Harrison Gruber on October 31, 2012 at 6:18 am
    I just completed logging and transferring all of my footage to start editing my project and lo and behold I notice that some of the footage is 1280×720 while some of the other footage is 1920×1080. What should I do? Can the two co-exist in the same sequence or will I have to do something to make them compatible?
    Panicked in L.A.
    Rafael Amador replied 13 years, 11 months ago 2 Members · 2 Replies
  • Harrison Gruber
    October 31, 2012 at 6:20 am
    p.s. All footage is Pro Res 422 and 23.98 but the data rates are also different. Ahhhhhh!!!! 🙁
  • Rafael Amador
    October 31, 2012 at 9:49 am
    No problem. Edit on a 1280×720 sequence.
    If you do the other way, you will need to blow up a lot the 1280×720 stuff and will lose quality.
    [Harrison Gruber] “p.s. All footage is Pro Res 422 and 23.98 but the data rates are also different. Ahhhhhh!!!! :(“
    As should be.
    With the same time base and with same codec, the 1920×1080 will have much higher data rate than the 1280×720 footage.
    rafael.
    http://www.nagavideo.com
