Activity Forums VEGAS Pro Mixed frame-rate 30p & 24p on timeline, best way to render to DVD & BDR?
  • Mixed frame-rate 30p & 24p on timeline, best way to render to DVD & BDR?
    Posted by Jim Greene on November 2, 2011 at 1:28 pm
    I mistakenly shot footage in 30p on one camera and 24p on the other. I normally shoot all 24p. So now how to deal with mixed footage. I think the answer is to set the project to 24p and have the timeline simply render all footage to 24p (with 2-3 pulldown for DVD). Is this the best way? Also, will the Blu-ray render template of “Blu-ray 1920×1080-60i, 25 Mbps video stream” be appropriate for BDR?
    Note: I’ve tried this mixed footage of render to 24p with project set to 24p and sometimes I get weird results, with the 30p files flickering horribly, but then copy/paste events to another 24p project and it renders normally.
    -Jim.
    John Rofrano replied 14 years, 10 months ago 2 Members · 3 Replies
  • John Rofrano
    November 2, 2011 at 2:02 pm
    [Jim Greene] “I think the answer is to set the project to 24p and have the timeline simply render all footage to 24p (with 2-3 pulldown for DVD). Is this the best way?”
    That’s what I would do.
    [Jim Greene] “Also, will the Blu-ray render template of “Blu-ray 1920×1080-60i, 25 Mbps video stream” be appropriate for BDR?”
    No. I would use the “Blu-ray 1920×1080-24p, 25 Mbps video stream” since your project is 24p.
    [Jim Greene] “Note: I’ve tried this mixed footage of render to 24p with project set to 24p and sometimes I get weird results, with the 30p files flickering horribly, but then copy/paste events to another 24p project and it renders normally.”
    Try right-clicking on each of the 30p events, go to Properties… and select Disable Resample. That might help.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jim Greene
    November 2, 2011 at 2:21 pm
    oops, that was a typo of BDR setting, I meant 24p. Thanks for the tip on resampling. Not only did that work, but the render is SO much faster on those clips. Thanks!!
    -Jim.
  • John Rofrano
    November 2, 2011 at 2:26 pm
    [Jim Greene] “Thanks for the tip on resampling. Not only did that work, but the render is SO much faster on those clips. Thanks!!”
    You’re welcome. That’s because it was trying to blend 30 frames into 24. By disabling resample, you told it to just drop 6 frames out of every 30 and use the remaining 24 so it has a lot less work to do.
    ~jr
