Activity › Forums › Apple Final Cut Pro Legacy › Mixed formats on timeline
  • Mixed formats on timeline
    Posted by Walter Miale on January 4, 2010 at 11:52 pm
    (For FCP7), is it OK to have mixed formats (eg ProRes 422sd and dv) on the same timeline? How? Do I just select the frame or frames I want to change and then assume the rest of the timeline won’t change?
    Shane Ross replied 16 years, 9 months ago 3 Members · 3 Replies
  • Rafael Amador
    January 5, 2010 at 12:59 am
    Walter,
    FC will cope well with different codecs and sizes in the same sequence, but not with stuff with different time-base.
    Rafael
    http://www.nagavideo.com
  • Walter Miale
    January 5, 2010 at 2:07 am
    I see, thank you.
    BTW Rafael, your videos are magnificent, as you well know. I’m watching them over and have to pry myself away.
    Walter
  • Shane Ross
    January 5, 2010 at 7:46 am
    You CAN edit mixed frame rates…FCP will play them. But not very well. Internally it doesn’t add/remove pulldown properly. When it comes to frame rates, best to have uniformity.
    Shane
