Activity › Forums › Apple Final Cut Pro Legacy › Mixed format & DVD
  • Mixed format & DVD
    Posted by Jim Makichuk on April 3, 2012 at 8:56 pm
    Based on a previous post I decided to use ProRes 422 and 16:9 format with DV50 Anamorphic combined with HD and photos. Project is a 4-5 min trailer for documentary funding.
    I loaded HD, photo and DV clip into timeline and it worked, DV had to be rendered first, but all looked good. I exported the test (1 min) to QT file and it looked good again, wide screen. Then exported to iDVD and this is what I got:
    Picture was not letterboxed on CRT TV and squeezed in, and HD TV picture was 16:9 but squeezed out.
    Any possibility of figuring out the best way to fix this or start with another method.
    Shane Ross replied 14 years, 5 months ago 2 Members · 4 Replies
  • Jim Makichuk
    April 3, 2012 at 9:52 pm
    I’m totally new to Compressor, having just worked in basics, iDVD, etc. I’ve tried with many failures behind me.
  • Jim Makichuk
    April 3, 2012 at 10:08 pm
    I’ve done some QT files, 1 minute tests, but not sure where to go with them. Mixing formats is not fun, at least for me, you never satisfy one or the other.
  • Jim Makichuk
    April 3, 2012 at 10:59 pm
    I have a good file with HD.DV & photo clip, test. It looks great, I just can’t seem to get it on DVD. Are you saying I could maybe use Compression to solve that? Via QT file?
  • Shane Ross
    April 4, 2012 at 2:57 am
    #42 – Quick and dirty way to author a DVD
    Shane’s Stock Answer #42 – David Roth Weiss’ Secret Quick and Dirty Way to Author a DVD:
    The absolute simplest way to make a DVD using FCP and DVDSP is as follows:
    1. Export a QT movie, either a reference file or self contained using current settings.
    2. Open DVDSP, select the “graphical” tab and you will see two little monitors, one blue, one green.
    3. Select the left blue one and hit delete.
    4. Now, select the green one, right click on it amd select the top option “first play”.
    5. Now drag your QT from the broswer and drop it on top of the green monitor.
    6. Now, for a DVD from an HD source, look to the right side and select the “general tab” in the track editor, and see the Display Mode, and select “16:9 pan-scan.”
    7. Hit the little black and yellow burn icon at the top of the page and put a a DVD in when prompted. DVDSP will encode and burn your new DVD.
    THATS ALL!!!
    NOW…if you want a GOOD LOOKING DVD, instead of taking your REF movie into DVD SP, instead take it into Compressor and choose the BEST QUALITY ENCODE (2 pass VBR) that matches your show timing. Then take THAT result into DVD SP and follow the rest of the steps. Except you can choose “16:9 LETTERBOX” instead of PAN & SCAN if you want to see the entire image.
    Shane
    Little Frog Post
