Activity Forums Apple Final Cut Pro Legacy Mixdown causes application Quits
  • Mixdown causes application Quits
    Posted by Boco007 on January 24, 2006 at 6:12 pm
    Hi Folks, thanks for the tip on mixing down it fixed the audio gaps. I have a new problem. Now I am just about done and I am mixing down the entire project. It keeps coming up application unexpectedly quits over and over. It goes all the way to the end then quits. I did delete all of the render files and re-rendered. That did not work either. Help, any ideas?
  • Bouncing Account needs new email address
    January 24, 2006 at 8:30 pm
    The first thing to always try is to Quit FCP, Restart the Mac, Open your FCP project and try again.
    Next:
    THE FOLLOWING COMES FROM THE KEN STONE WEBSITE:
    “Over 5,000 years ago Confucius wrote: ‘If you are toiling away, you have changed nothing and FCP heads South on you, [starts behaving in strange ways] then it is time to trash your FCP Preferences.’ ”
    Click the following link for instructions.
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    A great way to do this is to use “FCP Rescue” a free Apple Script that will Trash the Preferences for you (and restore nearly all of your user settings afterward).
    There are versions for FCP (Pro) & FCE (Express) and a new one for FCP 5.
    Download these free Apple Scripts at
    https://fcprescue.andersholck.com/
    or
    https://pistolerapost2.com/fcprescue/
    This is one FCP tip that has helped in solving hundreds of “odd” problems.
