Activity › Forums › Apple Final Cut Pro Legacy › Mix non HDV stuff and HDV footage on FCP 7
  • Mix non HDV stuff and HDV footage on FCP 7
    Posted by Lahoe Ku on August 18, 2011 at 7:49 pm
    Hi I have a question.
    I’m editing an interview shot by HDV using FCP 7.
    I want to insert various old materials on that.
    The materials are not HDV so I converted them using MPEG.
    I wonder if there is the best way to keep their ratio and work with them on HDV sequence without rendering everytime.
    Everest Mokaeff replied 15 years, 1 month ago 3 Members · 2 Replies
  • Chris Tompkins
    August 18, 2011 at 10:26 pm
    Convert all to prores.
    You can bring in the HDV to prores on ingest.
    Chris Tompkins
    Video Atlanta LLC
  • Everest Mokaeff
    August 18, 2011 at 10:35 pm
    Try to use ProRes codecs for all editing purposes unless you have to work w/ files coming straight from camera. Conventional wisdom is to capture HDV as is but change sequence codec to ProRes. It’s more productive had you to mix video w/ different resolution if they’d all ProRes files.
    Sony PMW-EX3, Canon Mark II 5D, FCS3 in Moscow
    http://www.mokaeff.com
