Activity Forums Panasonic Cameras Mistake in camera how to retrieve
  • Mistake in camera how to retrieve
    Posted by Tim Maloney on July 3, 2007 at 1:35 am
    Hello all,
    An associate has mistakenly shot some material intended for a 72060P @ 25fps project with the frequency on the varicam set @59.94.
    I have a FRC and a 1400 deck.
    Recording from the deck to the FRC results in stuttery slow down – of course.
    Can I retrieve the material?
    Best
    Tim Maloney
    Axis Films Australia
    Stephen De vere replied 18 years, 12 months ago 3 Members · 2 Replies
  • Bruce Greene
    July 3, 2007 at 1:50 pm
    I used film tools in Final Cut Pro software to convert footage from 23.98 fps to 25p and it worked out fine. I don’t do this stuff that often so I don’t remember the exact workflow, but I think you should be able to just change the time base of your footage to 25p pretty quickly using this tool.
    Try it and let us know if it worked.
    -bruce
    Varicam/Steadicam Owner
    Los Angeles, CA
    http://www.brucealangreene.com
  • Stephen De vere
    July 5, 2007 at 8:37 am
    From an HD Camera course I attended earlier this year in Bristol, run by BBC, I understood that this is not recoverable – atleast that there was no know conversion that would allow the result to pass BBC HD programming specs. I don’t know the technical reasons why.
    You could try asking Alan Roberts over on https://forums.dvdoctor.net/forumdisplay.php?f=35 (HDV and HD forum).
    He is a technical consultant who still does work for BBC and knows the Varicam and other HD cameras well.
