Activity Forums Apple Final Cut Pro Legacy Missing source clips names
  • Missing source clips names
    Posted by Sam Hilton on April 20, 2008 at 1:06 am
    I copied a bunch of clips onto a external drive for an edit on my laptop. when trying to re open the sequence and reconnect the media in the original suite the source clips names had disappeared and the source location of all the clips change to the external drive. The only way to reconnect the media was to manually find the location of each individual clip and reconnect it, there’s has to be another way!
    Katie Gillum replied 18 years, 2 months ago 4 Members · 5 Replies
  • Kristoffer Newsom
    April 20, 2008 at 7:01 am
    there should be a box you can check that says “Reconnect all media in this directory”, and that should do it, provided FCP thinks its offline.
  • Sam Hilton
    April 20, 2008 at 8:43 am
    It’s not working because the source clips don’t appear to have a name. when i try to reconnect it come’s up with the external hard drive as the source clip location, no names. but, the clip in the sequence appears with the naming convention, really strange.
  • Arnie Schlissel
    April 20, 2008 at 3:53 pm
    Did you rename your clips in FCP after you captured? Up until FCP 6, when you renamed your clip in FCP, the name of the original source did not change. Now, there’s an option to rename the original source when you change the name in FCP.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Sam Hilton
    April 20, 2008 at 10:58 pm
    No, the clip names weren’t renamed just moved to a different location i.e external hard drive.
    Then i reopened the sequence on another computer where the original media was stored and now the clips have no source location.
  • Katie Gillum
    May 17, 2008 at 11:16 pm
    Have you had any luck reconnecting the media at all? Even though I know where the source material is, I am not able to reconnect it at all because the clips all seem to have had their source names deleted some how.
