Activity › Forums › Apple Final Cut Pro Legacy › Missing sound in Compressor
  • Missing sound in Compressor
    Posted by Galen Fletcher on March 10, 2008 at 7:25 pm
    I have been trying to make a screener of a 15min uncompressed 10 bit HD timeline by sending it to compressor and running the 90 minute MPEG2 settings (both 1 and 2 pass). The picture works perfectly, but the sound refuses to show up.
    The audio is a stereo track that I received from our sound editor out of protools. In the time line it says .aif but when I look at the clip settings it says that it is an aifc file.
    I have a feeling this may have something to do with it, but in the preview window in compressor there is always sound.
    This is the latest version of Compressor on an 3.0 8 core macpro with 4 gigs of ram.
    Galen
    Galen Fletcher replied 18 years, 6 months ago 3 Members · 5 Replies
  • Matthew Nelson
    March 10, 2008 at 8:41 pm
    What you are making is an elementary stream for DVD encoding. These are unmuxed files. What you want is a program stream which you can find in the Formats/MPEG-2 inside Compressor settings.
    Matt
  • Jeff Carpenter
    March 10, 2008 at 8:43 pm
    You have to apply a video compression (which you’ve done) and an audio compression (which is sounds like you haven’t done).
    Go into any of the DVD pre-sets in Compressor and use the Dolby compression. It will create an audio file. You then use the MPEG II file and the Dolby Audio file in DVD Studio Pro.
  • Matthew Nelson
    March 10, 2008 at 8:55 pm
    Jeff is absolutely correct if you want to make a DVD. Program streams are self contained files. Follow Jeff’s workflow for DVD creation.
    Matt
  • Galen Fletcher
    March 10, 2008 at 10:20 pm
    I think that is indeed where my issue lies. In the Mpeg 2 pre-set it mentioned audio so I assumed that it automatically would bring the sound with it.
    When I am back in the suite tomorrow I will have another go at it.
    Thanks for the info.
    Galen
  • Galen Fletcher
    March 10, 2008 at 10:23 pm
    Actually I just realized that I have been doing it right but I haven’t been finding the sound file. It never occurred to me that they would be separate.
    Thanks again
    Galen
