Missing Sony Vegas 12 AVI Windows codec/DV25
Hi, everybody in Sony Vegas land! 🙂
I’m getting the infamous “File NNN.avi could not be opened” error message in Vegas Pro 12. Windows Media player will only play the sound of the file. This means, as far as I understand, that the correct video codec is missing in Windows 10. This leads me to the vital question: Where can I get a Windows codec (preferrably compatible with Windows 10, 64 bit or 32 bit) that will do the trick?
MediaInfo reports as follows:
General
Complete name : NNNN.avi
Format : AVI
Format/Info : Audio Video Interleave
Commercial name : DVCPRO
Format profile : OpenDML
File size : 12.3 GiB
Duration : 57mn 1s
Overall bit rate mode : Constant
Overall bit rate : 30.8 MbpsVideo
Format : DV
Codec ID : dv25
Codec ID/Hint : DVCPro
Duration : 57mn 1s
Bit rate mode : Constant
Bit rate : 24.4 Mbps
Encoded bit rate : 28.8 Mbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:1:1
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Bottom Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 2.357
Stream size : 11.5 GiB (93%)Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Duration : 57mn 1s
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 626 MiB (5%)
Alignment : Aligned on interleaves
Interleave, duration : 11 ms (0.27 video frame)
Interleave, preload duration : 288 msI’ve installed the FFMPEG codecs, as well as FFDSHOW and K-Lite Basic, unfortunately to no avail. The tuning and tweaking options are plentyful, but I’ve refrained from doing too much out of it as of yet.
The source of the .avi file is Pinnacle VideoStudio 19, used for capture of some old Betamax footage. (30+ years old, still playing with the same great quality as ever 🙂 ) And yes, I’ve installed that software as well on the Vegas computer, but apparently no DV25 codecs from Pinnacle either.
Looking forward to hearing from you!
Kind regards,
Arnt Richard.
