Activity Forums Blackmagic Design Missing scopes in Premiere Pro
  • Missing scopes in Premiere Pro
    Posted by David Braswell on February 16, 2006 at 8:40 pm
    I’m posting this here on the off chance it’s somehow related to our Decklink SP card. We’re using the SP on an approved dual Xeon system with 2G RAM. Editing in Premiere Pro 1.5.1, I noticed the software waveform and vector scopes would not start. Currently running the latest (5.4) driver. Any others with this problem?
    David Braswell replied 20 years, 7 months ago 5 Members · 5 Replies
  • Shane Chadder
    February 16, 2006 at 9:20 pm
    I have this problem to. Someone earlier posted this was fixed in 5.42 which is the current Decklink driver but I haven’t tested this yet.
  • Andrew Mcleod
    February 17, 2006 at 3:25 am
    Yes scopes in Premiere Pro 2.0 are working in Decklink 5.4.2.
    let me know if you have any problems.
    pcsupport@blackmagic-design.com
    Andrew McLeod
    Blackmagic Design
  • John Baum
    February 17, 2006 at 2:43 pm
    But they apparently don’t fix the issue with 8bit footage in After Effects 7. It still crashes on import.
  • Kristian Lam
    February 17, 2006 at 2:55 pm
    [ghobii] “But they apparently don’t fix the issue with 8bit footage in After Effects 7. It still crashes on import.”
    Yes, that issue is not resolved yet. But we’re working on it.
  • David Braswell
    February 20, 2006 at 12:09 am
    Thank you. I’ll try the new drivers soon as I can.
