Activity Forums Adobe After Effects missing matte feather effect in after cc
  • missing matte feather effect in after cc
    Posted by Jovan Strel on September 8, 2013 at 8:19 pm
    hi,
    after effects is reporting every time I start the program that the effect matte feather is missing –
    its seems weird because normally while i’m working with masks it is showing me feather applied but when its time to render it renders out mostly blank frames
    i’ve been doing roto for days, and this problem occurred midway.
    i’ve reinstalled the program but no dice
    thanks for help
    Jovan Strel replied 13 years ago 2 Members · 2 Replies
  • Todd Kopriva
    September 9, 2013 at 4:47 am
    Are you referring to the third-party Composite Wizard Matte Feather effect?
    There is no Matte Feather effect in After Effects.
    If a plug-in is reported as missing, it’s because you don’t have that plug-in installed (or not installed in the right place).
    After Effects team blog
  • Jovan Strel
    September 10, 2013 at 11:14 am
    thanks for response
    the problem is when i use feather on masks, (those basic ones made with pen tool) during render time all those masks with feather dont get rendered
    while i’m working those mask work fine, what they are supposed to – but when i render out only sharp fasks(with 0 feather) get rendered
    i suppose that two problems are linked together, because on the day i started getting missing effect note, rendering masks became a issue.
