Activity Forums VEGAS Pro missing markers
  • missing markers
    Posted by Wouter Slagter on February 15, 2013 at 6:58 am
    I don’t know why my markers don’t show up after I render a project.
    I have it selected as automatically save markers with media in Preferences and I have it selected with a render template as well.
    Am I missing here something?
    John Rofrano replied 9 years, 3 months ago 5 Members · 13 Replies
  • 13 Replies
  • John Rofrano
    February 16, 2013 at 12:32 pm
    Where don’t they show up? What type of media did you render? Not all video formats have the capability of embedding markers.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Frank Tomlin
    February 17, 2013 at 5:48 pm
    I’m having the same trouble with Vegas Pro 12. Trying to use the file as input to Architect 6.0.
    I “render as” Main Concept MPEG-2 -> DVD Architect NTSC Widescreen Videostream.
    Saw a youtube video that showed a file created with “Movie Studio” using chapter markers came into Architect with the markers showing up.
    I see there’s an option in Architect that allows you to “insert scene/chapter marker”, but I hate to have to redo it (have 30+ chapters).
  • John Rofrano
    February 17, 2013 at 6:45 pm
    [Frank Tomlin] “I’m having the same trouble with Vegas Pro 12. Trying to use the file as input to Architect 6.0. I “render as” Main Concept MPEG-2 -> DVD Architect NTSC Widescreen Videostream.”
    Did you turn on the option to Save project markers in rendered media file under Metadata Options?
    If you did, then did you move the MPEG2 file after rendering it? If so, did you move the marker file because the chapter markers are not embedded in the MPEG2 file, they are placed in a separate file that must remain in the same folder as the MPEG2 file.
    ~jr
  • Frank Tomlin
    February 17, 2013 at 11:59 pm
    Thanks for the reply John.
    I missed that check box originally.
    That did it!
    Thanks again.
  • Wouter Slagter
    February 18, 2013 at 6:31 am
    Hi John,
    Sorry for not being more specific.
    In Vegas Pro 12, I rendered as Sony AVC with “Save project markers in rendered media ” selected in Meta Data Options.
    Then I imported the rendered file into DVD Architect and the markers did not show up in the timeline.
    There is an icon on the timeline in Architect “Load Markers” but I thought that’s only used if you add markers directly on the timeline in Architect.
  • John Rofrano
    February 18, 2013 at 1:14 pm
    [Frank Tomlin] “I missed that check box originally.”
    Yea, if you’re using Vegas Pro 12.0 the new render dialog is very confusing. I guess someone thinks it’s an improvement, but I haven’t met anyone else who agrees. 🙁
    ~jr
  • John Rofrano
    February 18, 2013 at 1:19 pm
    [Wouter Slagter] “Then I imported the rendered file into DVD Architect and the markers did not show up in the timeline. “
    Did you move the media file after you rendered it? The markers are saved in a separate file and if you move the media and you don’t move the marker file they will not show up.
    [Wouter Slagter] “There is an icon on the timeline in Architect “Load Markers” but I thought that’s only used if you add markers directly on the timeline in Architect.”
    No, that button is to load a markers file like the one that Vegas Pro creates.
    ~jr
  • Patrick Smith
    September 9, 2015 at 11:21 pm
    John I know this is an old thread, however I have not moved the rendered file, yet the project markers have not transferred across for this project, whilst they normally do. This is my first project with Vegas pro 13, and DVDA 6.0. Previously I used VMSP10 and DVDA 5.0.
    Check box for markers is selected. A separate file was not created, as there is only my rendered file in that location.
  • John Rofrano
    September 12, 2015 at 12:05 pm
    If you checked the box to create markers during render, there should be a file with the same name as your MPG file with the extension .sfl. See if that file is there. If it is, you can manually load it into DVD Architect using the load chapters button. If not, are you sure you created the chapter markers correctly. There are several different types of markers in Vegas Pro. Only the regular Markers (not command markers, or close caption markers, etc.) will create chapters.
    ~jr
  • Ellen Garvey
    May 14, 2017 at 11:44 pm
    Joining in on this old thread, as I’ve switched to V14 and can’t seem to get the markers out. I don’t know if it’s still applicable but I can’t find the “option to Save project markers in rendered media file under Metadata Options” referred to in this thread.
    Also, I DO have an SFL file but when I use the “load markers” button in architect nothing happens (of course I’d prefer that they be embedded).
    Using Movie Studio 14 Platinum (same problem with 13)
    MPEG-2 – either DVD or Blu-ray.
    Checkbox for “insert i-frames at markers” is checked (under “customize” under template).
    I went back and rendered a test using Vegas 10 and Architect imports with markers just fine, so I’m sure the problem is the Vegas 14 rendering.
