Activity Forums Apple Final Cut Pro Legacy missing log and capture viewer in Final Cut 6.06
  • missing log and capture viewer in Final Cut 6.06
    Posted by Joe Cunningham on February 28, 2012 at 2:31 am
    For some reason, the viewer in my log and capture has disappeared, which means I cannot set in/out and disable audio capture from my Panasonic HDC-TM700 camera.
    Shane Ross replied 14 years, 6 months ago 3 Members · 5 Replies
  • Jerry Hofmann
    February 28, 2012 at 3:03 am
    The window doesn’t open or you can’t see any video in it?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Shane Ross
    February 28, 2012 at 3:11 am
    Log and Capture is for TAPE based cameras. This camera shoots TAPELESS. For that, you use Log and Transfer:
    Tapeless Workflow for FCP 7 Tutorial
    Shane
    Little Frog Post
  • Joe Cunningham
    February 28, 2012 at 3:16 am
    Thanks for your rapid response. When I open log and capture, all I see are the thumbnails and info columns, but the viewer is missing in action. I don’t have a clue as to what I may have done to make it disappear, and have tried clicking on every possible button.
    If it helps, I’m using a dual core intel Xeon MacPro with 4GB ram and OS 10.5.8
  • Joe Cunningham
    February 28, 2012 at 3:26 am
    Ooops. sorry for the bogus info. I meant log and transfer. The problem just manifested last week. I rarely deal with tape anymore…thank God.
  • Shane Ross
    February 28, 2012 at 4:28 am
    Trash your preferences
    Shane
    Little Frog Post
