Activity Forums Apple Final Cut Pro Legacy missing file
  • Posted by Mark Barroso on November 11, 2009 at 4:37 pm
    I export my file to compressor and it says I have a missing file. I search (apple+ F)the browser, the timeline and even the entire computer and can’t find it. I scroll through the timeline looking for a “Missing Media” thumbnail and there is none. From researching here I understand it could be in a render file. I don’t think (but possible) it is in a nested sequence because those sequences are of an entirely different scene.
    I re-rendered the sequence in case it makes a difference.
    Any ideas of what’s going on? If my sequence looks fine, can I just ignore the warning? What’s the fix or work around if I can’t find the file to re-connect it?
    FCP 6.0.5 /
    OS 10.4.11 /
    Mac Pro 2×2.66 Ghz Dual Core/ 2G RAM
    External: FW800 G-tech 500 HD and G-Tech Quad 750GB
    playback deck: Pan dv2500
    Mark Barroso replied 16 years, 10 months ago 2 Members · 2 Replies
  • John Fishback
    November 11, 2009 at 9:06 pm
    You can use Render Manager to delete your renders and then re-render, to see if that helps. Or first, try exporting a ref or self-contained QT with current settings. See if Compressor will run with that file.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Mark Barroso
    November 13, 2009 at 11:16 pm
    Thanks, John. I’m in the process of doing your first option and it seems to be working, although I have to re-capture some clips.
    FCP 6.0.5 /
    OS 10.4.11 /
