Activity › Forums › Adobe After Effects › Missing Effect Controls
  • Missing Effect Controls
    Posted by Hadditor Harding on August 8, 2013 at 12:07 pm
    The effect controls window is entirely missing. It isn’t under the Windows dropdown menu, and when I right click on an effect the “Reveal in Effect Controls” button is simply grayed out! Well, I am stumped and can’t find an answer anywhere else… Please help!
    Todd Kopriva replied 13 years, 1 month ago 3 Members · 2 Replies
  • Jonathan Ramsey
    August 8, 2013 at 5:36 pm
    You can try changing your Window>Workspace to another setting and see if it shows up. It’s probably just hidden under another window. Things can get messy quickly in AE if you dock and undock panels/frames. Look carefully at all the tabs in every panel. some make you scroll right/left to see the tabs.
    Ramsey
  • Todd Kopriva
    August 8, 2013 at 6:48 pm
    Did you open the render engine, not the full After Effects application?
    After Effects team blog
