  • Posted by Alan O’rourke on June 29, 2005 at 11:28 am
    Hi all,
    I have gone back to an old project created in after effects 5 (now on v6) but it is telling me that i am missing 14 effects because i no longer have twixtor 3 as i have updated to v4. Is there any way to point after effects at the new version of twixtor without going in and re doing all the effects one by one?
    Al
    Peter Litwinowicz replied 21 years, 1 month ago 3 Members · 3 Replies
  • Serge Hamad
    June 29, 2005 at 2:36 pm
    Not sure if this works but…
    Try to install Twixtor 3 in AE 6.0, open your AE 5.5 project save it then upgrade to Twixtor 4.
    Good luck.
    Salut.
    Serge
  • Peter Litwinowicz
    July 9, 2005 at 4:43 am
    If you still have your Twixtor 3 key (which hopefully you do since you upgraded to version 4 and didn’t start with version 4) you can install Twixtor 3 available here : https://www.revisionfx.com/rstwixtordownloadsOldAE.htm .
    You can then simply use Twixtor 3 or copy your settings to the twixtor 4 plugin (or better yet, link the values that are animated via expressions).
    Pete Litwinowicz
  • Peter Litwinowicz
    July 9, 2005 at 4:44 am
    If you still have your Twixtor 3 key (which hopefully you do since you upgraded to version 4 and didn’t start with version 4) you can install Twixtor 3 available here : https://www.revisionfx.com” target=”_blank”>https://www.revisionfx.com/rstwixtordownloadsOldAE.htm .
    Pete Litwinowicz
