Activity › Forums › DaVinci Resolve › Missing audio on XML imports from FCPX
  • Missing audio on XML imports from FCPX
    Posted by Jim Bachalo on June 10, 2014 at 12:16 pm
    Read this blog post on 1 way trip with resolve
    https://www.thefilmbakery.com/blog/one-way-trip-with-resolve-10
    so was excited to try on my own project.
    Unfortunately none of my audio files are importing
    I get the error
    The clip “FOO-Stereo’ failed to link because the media file ‘foo.aif’ is missing or has the wrong timecode extents.
    This happens with .wav files as well.
    Could this possibly be something to do with my conform options in my Resolve Project setting gs or…?
    Really would like to get this working…
    You should follow me on Twitter here. My latest work
    Jim Bachalo replied 12 years, 3 months ago 2 Members · 2 Replies
  • Eric Johnson
    June 13, 2014 at 9:30 pm
    Have you tried to import the stems via the media pool? Reading the article, is doesn’t say that they sent the Stems from FCP to Resolve, only that they had previously used FCP to sync final audio and picture post grade in the past.
    You are able to perform the same sync process in the Resolve timeline.
    eric b johnson
    online editor | colorist | workflow
    https://vimeo.com/ebjohnson/colorreel
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Jim Bachalo
    June 13, 2014 at 10:32 pm
    Thanks. No the issue is the bit rate. Using 96kHz 24 bit masters. Resolve won’t accept anything higher than 48kHz. Hopefully this is fixed in the 11 release!
