Activity Forums Adobe After Effects Expressions minus sign in external data = bug ?
  • minus sign in external data = bug ?
    Posted by Nicolas Elsig on June 1, 2012 at 1:48 pm
    hello I’m loading external data from a text file … everything is fine with the eval expression taking the data based on the name of the comp
    here’s the external data
    Sion = [“+23°C”,”+36°C”];
    Monthey = [“+1°C”,”+25°C”];
    St-Gingolph = [“-6°C”,”+21°C”];
    the last line St-Gingolf is making AE to say : warning Class “global” has no property or method named “St” Expression disabled
    can somebody help please ?
    myPath = "/Expressions/";
    myPath += "externalData.txt";
    $.evalFile (myPath);
    eval(thisComp.name)[0];
    Nicolas Elsig replied 14 years, 3 months ago 2 Members · 2 Replies
  • Dan Ebberts
    June 1, 2012 at 2:58 pm
    St-Gingolph is not a valid variable name in JavaScript. St_Gingolph would work.
    Dan
  • Nicolas Elsig
    June 2, 2012 at 6:52 am
    Thank you Dan for the precision. I will work with an underscore.
