Activity Forums Apple Final Cut Pro Legacy MiniDV to Beta SP workflow???
  • MiniDV to Beta SP workflow???
    Posted by Thomas on August 29, 2006 at 6:52 pm
    Can someone tell me what kind of settings I should have for BetaSP? I know that it’s 720×486 but what about the other settings in FCP?
    I’ve already edited a project in a timeline sequence all set for MiniDV and now I need to export it out to BetaSP.
    Should I export the clip to BetaSP settings or just make a new sequence set for BetaSP and then render the DV footage?
    Rennie Klymyk replied 20 years ago 4 Members · 5 Replies
  • Bouncing Account needs new email address
    August 29, 2006 at 7:06 pm
    I output to BSP every day from a DV timeline.
    Since BetaSP is analog, you just connect the Beta Deck to an output card or DV unit connected to the Mac…
    and record via the composite (good), S-Video (better) or Component (best) input to the Beta deck.
    (Audio must be connected as well, of course.)
  • Thomas
    August 29, 2006 at 7:10 pm
    so do I just keep the DV settings the same in the timeline sequence and then just output it to BetaSP?
    I thought that you you would have to change the pixel ratio from 720×480 to 720×486?
    August 29, 2006 at 7:16 pm
    Those fewer six pixels would not stop any of my local stations from running a paid TV spot, no.
  • Walter Biscardi
    August 29, 2006 at 7:50 pm
    [Thomas] “so do I just keep the DV settings the same in the timeline sequence and then just output it to BetaSP?
    I thought that you you would have to change the pixel ratio from 720×480 to 720×486?”
    Nope. just get an AJA Io LA or a Kona product and play your DV timeline direct to Beta via Component or S-Video. It’s a realtime playback so you can just edit in DV as normal but lay-off to Beta for broadcast.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Rennie Klymyk
    August 30, 2006 at 7:27 pm
    The only other think to watch is set up. If you’re dv is set to 0 ire black level you need to switch the “add set-up” switch on the beta deck “on” or you can change this in your aja control panel. A wf monitor on the end of the beta deck is always nice.
    “everything is broken”
