Activity Forums Panasonic Cameras MiniDV splash bag for DVX100B underwater pool shooting
  • MiniDV splash bag for DVX100B underwater pool shooting
    Posted by Filmstudent on September 30, 2007 at 4:56 pm
    Hello,
    Does anyone know anything about the following product that i am going to rent for underwater shooting in a residential pool (max 6ft deep) with the DVX100B? It’s called a MiniDV splash bag and I am looking to rent it from Air Sea Land Productions (out of NYC):
    Basically I want to make sure that the product is reliable and that my camera won’t get wet.
    This housing is made from 2mm thick natural latex and is sealed using a heavy-duty watertight zip. The front and rear ports are fixed to an internal shoe. The camera is mounted onto an adjustable quick release plate on this shoe. This allows the camera to be positioned within the housing depending on the lens used.
    Designed to fit most Sony, Canon, JVC and Panasonic Mini DV camcorders
    The housing can be either hand held or mounted on a tripod. Access to the “stand by” switch and the “tape run” button is achieved using the fingerstall in the body of the housing, and the zoom rocker switch can be operated through the wall of the housing. When the zip is fully closed the unit can be submerged to a maximum depth of 3 meters.
    Noah Kadner replied 18 years, 7 months ago 2 Members · 1 Reply
  • Noah Kadner
    October 1, 2007 at 1:45 pm
    Sounds a bit flimsy- ask what the dryness guarantee is on that one…
    Noah
    Unlock the secrets of the DVX100 and now Apple Color!
    https://www.callboxlive.com
