Activity › Forums › Apple Final Cut Pro Legacy › MiniDV key – whether i Like i or not.
  • MiniDV key – whether i Like i or not.
    Posted by Arnljot Bringedal on July 20, 2007 at 5:47 pm
    Hey!
    Received some chromakey-footage from a source that i need to key.
    The bakground is a kinda nice lit green chromakey
    ( available sunlight, but on a shadow day – so pretty even )
    – but the recording is Dv PAL – and I know this will give me headache….
    Have never keyed this kind of footage before.
    Whats the best way? FCP ? MOTION? AE? Cs3 ULTRA?
    (Would like to stay inside FCPS2 if avisable )
    special tips someone?
    *** Norwegian videojournalist & Editor***
    Arnljot Bringedal replied 19 years, 2 months ago 4 Members · 4 Replies
  • Zak Mussig
    July 20, 2007 at 7:19 pm
    DV can be a pain because of the compression. I’m a big fan of dvGarage’s dvmatte pro. I’ve only used it with HDV, but it’s designed to work around the color sampling of lower-grade formats like DV and HDV.
    This is a $200 plug-in, so maybe not the way to go if cost is a higher priority than quality. Sometimes we all just have to work with what’s already in front of us.
    If that doesn’t work for you, I would still stay in FCP unless you have AE. Garbage matte your footage and use multiple instances of a keyer rather than trying to stretch one to do everything.
    Hope that helps,
    Zak
  • Dan Sparks
    July 20, 2007 at 11:50 pm
    My new favorite for DV keying. vkey2 keyer
    We’d all prefer to key from better tape formats, but sometimes you deal with the tapes your handed 😉
    Dan Sparks
    Tricom Video
  • Rafael Amador
    July 21, 2007 at 4:22 am
    Which ever program you use apply first a chroma smoothing filter this will help you to pull a key from DV footage.
    cheers,
    rafael
  • Arnljot Bringedal
    July 22, 2007 at 9:59 am
    Thanks guys!
