MiniDV Camcorder and 1394 Not Working in Vista
I posted this in the Vegas Basics forum, but Mike Kujbida recommended I post this here because he had not run across this issue before, or at least to the extent I’ve experienced this problem.
Equipment:
JVC GR-DV 900 camcorder using miniDV tape
Sony Vegas Studio Platinum 8
Acer Core2Quad Q6600 with 4 GB RAM
Windows Vista with SP2Initial issue: Vista (and Video Capture in Vegas Studio) recognized my camera and could capture footage off the tape, but the resulting footage was very choppy and even pixellated. Mike recommended using DV instead of the mini USB, so I bought a 4-to-6 DV cable.
Now the problem is actually worse! Vista recognizes the 1394a port built into the Acer motherboard (a VIA chipset), but it will not recognize my JVC camera. I contacted JVC, and they claim this is a known issue with miniDV tape-based camcorders, 1394a ports, and Windows Vista with NO KNOWN SOLUTION!!! They say it works in Windows XP, but my PC didn’t come with XP so I can’t roll it back.
Microsoft says the issue is that Vista “only enumerates a device that sets its link status to request enumeration. If an IEEE 1394a device does not report the correct status of its link, the IEEE 1394 stack in Windows Vista does not enumerate the device.” They suggested a registry hack (MS KB article 927827) and/or a firmware update. I couldn’t find the latter, and after applying the hack Vista still didn’t recognize my camcorder.
In performing a Google search, one user said to apply this registry hack, then power down both camcorder and computer; turn on the camera and start playing the tape, then turn on the computer, and Vista should recognize the camcorder. It didn’t.
I’ve also upgraded to Service Pack 2 (surprised it hadn’t automatically installed by now), but that hasn’t helped either.
An interim solution is to install a Firewire card on my work computer (XP Pro), capture the video and save it as AVI, and then copy that file onto my home computer with Vista.
As previously noted, I cannot roll back to XP since my home computer came with Vista pre-installed, so that fix is a no-go.
I’d really rather try to fix this rather than use the kludge solution. Any suggestions long-term?
