Activity Forums Apple Final Cut Pro Legacy Mini DV capture in FCP – Losing quality
  • Mini DV capture in FCP – Losing quality
    Posted by Brett Blake on April 14, 2010 at 7:06 pm
    Hi all-
    I’m having a very strange problem while capturing Mini DV into FCP 6.0.5.
    When I look at the video in the Log and Capture window, the quality is superb, but when I capture it, it becomes washed out and less crisp. I’m using the NTSC DV capture setting with the quality set at “Best.” I’ve also tried a number of other settings to see if I could get the quality up, but no dice.
    I know that Mini-DV into Final Cut should be a lossless transfer, but I’m getting much lower quality when all is said and done.
    Any suggestions?
    Rafael Amador replied 16 years, 5 months ago 3 Members · 3 Replies
  • John Fishback
    April 14, 2010 at 7:29 pm
    How are you capturing-camera or deck, Firewire or capture device?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Brett Blake
    April 14, 2010 at 8:03 pm
    Hi John-
    Should have included this in the original post. I’m using a DVCAM Deck with a FireWire 400 connection.
  • Rafael Amador
    April 15, 2010 at 4:00 am
    No way that any degradation is happening.
    If you would monitor properly the video in tape and in FC you would find no difference.
    rafael
    http://www.nagavideo.com
