Activity › Forums › Adobe Premiere Pro › Migrating to a new MBP
  • Migrating to a new MBP
    Posted by Jim on April 10, 2015 at 10:44 pm
    I have just purchased a new MBP and am a CC subscriber(and have CS6). I’m considering the best ways to move from my old MBP to the new.
    The Apple store folks suggest using Time Machine, which is supposed to be pretty painless, and considering all of the plug-ins and their serial # etc, is most tempting. However, a new machine will allow a clean install, which in the long run may avoid other performance issues.
    Any sage advice?
    Jim
    Ht Davis replied 11 years, 5 months ago 2 Members · 1 Reply
  • Ht Davis
    April 17, 2015 at 3:32 am
    Run FAR FAR AWAY.
    No, jk. A clean install will get it all back, but with Yosemite, there are still a lot of issues. Be prepared to contend with those. If you want your prores back, you’ll have to install your apple codecs first, then install the preset that matches the codecs. For compressor 3 and below, use the cs6 set, for compressor 4 and above, use the CC set.
    As for time machine… …useless for anything but your documents. Unfortunately, there aren’t as many useful options for moving on the mac as there are for pc. Use to be that I you could use firewire to move the files and profile without disturbing the system, even some of the apps. Not anymore. Truly unfortunate.
    Acronis has an imaging software, but I haven’t tried it. You might check with them. They might be able to do their imaging and recover all the drivers and such into place much like with their windows software. Their windows software allows you to upgrade to a newer machine, keeping the same software and locations, but allows you to upgrade and replace drivers first.
