Activity Forums Avid Media Composer Migrating projects back and forth between AVID 7 AND AVID 8
  • Migrating projects back and forth between AVID 7 AND AVID 8
    Posted by Jake Frader on January 15, 2015 at 3:15 pm
    Does anyone know if I can go back and forth from Avid 7 and 8 (Open a project in Avid 8, then the next day open a project in Avid 7, and vice versa?). Will the project files remain intact?
    Any help would be greatly appreciated!
    Thank you!
    Shane Ross replied 11 years ago 5 Members · 10 Replies
  • 10 Replies
  • Shane Ross
    January 16, 2015 at 1:24 am
    Everything will be fine. However, whatever features you use that are MC 8 only, that MC7 doesn’t have…won’t transfer back. Such as deactivating clips in the timeline…4K media support…stuff like that.
    Shane
    Little Frog Post
  • Pat Horridge
    January 16, 2015 at 9:04 am
    You need to have the latest point release for V7 which is 7.0.4.2
    Also easier and safer to not swop projects just bins and media.
    Pat Horridge
    Technical Director, Trainer, Avid Certified Instructor
    Free online Tutorials at VET digital media academy online https://vimeo.com/channels/752951
    VET
    Production Editing Digital Media Design DVD
    T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
    http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US
  • Jake Frader
    January 17, 2015 at 7:11 pm
    Thank you both for your help! It is quite appreciated!
  • Desireena Almoradie
    February 22, 2015 at 10:57 pm
    will i be able to migrate back and forth between 6.5 and 8 just as easily? or does this only work for versions 7 and 8?
    Thanks for your help
  • Shane Ross
    February 23, 2015 at 2:15 am
    Bin and project wise, yes. But many new features found in MC8 won’t be in MC6.5.
    Shane
    Little Frog Post
  • Mike Scannel
    August 24, 2015 at 6:23 pm
    Does it have to be 7.0.4.2 or is 7.0.4 good enough?
  • Shane Ross
    August 24, 2015 at 6:30 pm
    It’s the last .2 that makes this possible. It’s a free update…
    Shane
    Little Frog Post
  • Mike Scannel
    August 24, 2015 at 6:51 pm
    Cool. Thanks. I am assuming the 7.0.4.4 update will do the trick as well. Do you have any idea if the 7.0.4.4 update supports projects created in MC8 on PC to migrate back and forth from MC 7.0.4.4 on Mac?
  • Shane Ross
    August 24, 2015 at 7:04 pm
    Sorry…, I meant .4.
    https://avid.force.com/pkb/articles/en_US/FAQ/Media-Composer-8-FAQ#General%2018
    Q: Is the Media Composer | Software (v8) license backwards compatible to Media Composer v7 or earlier?
    A: We have released Media Composer 7.0.4 and Media Composer 6.5.4.2 that will run on a Media Composer | Software (v8) perpetual software or dongle license. They will not, however, run using a Subscription or Floating license. Please refer to this Knowledgebase article for more information.
    Shane
    Little Frog Post
  • Shane Ross
    August 24, 2015 at 7:07 pm
    You need the latest patches in order to do this….basically.
    Shane
    Little Frog Post
