Activity Forums Apple Motion Midi Keyboard & Motion 2
  • Midi Keyboard & Motion 2
    Posted by Ryan Cates on June 2, 2005 at 6:11 pm
    I am using the M-Audio Keystation 49e – USB Midi Keyboard with Garageband 2. Can I use this with my soon to be arriving Motion 2? If not, what should I look at? Thanks in advance!
    Dan Luke replied 21 years, 3 months ago 3 Members · 3 Replies
  • Azariah Owens
    June 2, 2005 at 10:51 pm
    I’d guess at: yes.
  • Dan Luke
    June 3, 2005 at 2:17 am
    i have the same keyboard and motion 2. I spent all my playtime today with threplicator. Tomorrow i’ll try the keyboard.
  • Dan Luke
    June 4, 2005 at 2:02 am
    M-audio 49e works with motion 2. There is a behavior called midi, you apply it to an object, then in the learning mode of the behavior you hit a key and that key is assigned to that behavior. Then you have the option to do a bunch of different modifiers. So it’s one key per midi behavior. I set-up the lower c note to move right on the x axis and the volume fader to move on the y axis. and the b note to move left on the x axis. This needed 3 instances of the midi behavior but was easier to do than to type this out.
