Activity › Forums › Event Videographers › Microdolly/ Glidecam pan and tilt heads, which one would you recommend it?
  • Microdolly/ Glidecam pan and tilt heads, which one would you recommend it?
    Posted by Samuel A. martin on September 10, 2005 at 11:21 pm
    Hi:
    Would you recommend the microdolly power head over glidecam’s pan and tilt remote head? I would use it with small DV and HDV cameras. May be with a DSR570/ 450 once in a while….. Would I be able to use with my EZFX jib?
    How does it compare with varizoom’s? Does it justify the price difference? Any other systems people would recommend?
    Sam
    Samuel A. martin replied 21 years ago 1 Member · 0 Replies
  • 0 Replies
