Activity › Forums › Sony Cameras › micro in CH1
  • micro in CH1
    Posted by Günther Dilger on July 9, 2009 at 5:08 pm
    In the manual it says, that micro connected on CH1 saves signal on both channels. But in earphone (with correct stereo plug) I can hear the input only on one side; it seems, that CH1 forwards only to one channel. What can I do to hear both channels in earphone?
    Craig Seeman replied 17 years, 2 months ago 2 Members · 3 Replies
  • Craig Seeman
    July 9, 2009 at 5:32 pm
    In software Audio Input you can set the CH-1 which sends Channel 1 to both channels or you can set CH-1/CH-2 in which they are separate.
  • Günther Dilger
    July 9, 2009 at 5:51 pm
    Thanks, also this we found out now ourselves :-(. But in the manual it sounded like CH1 automatically forwards to both channels if internal and CH2 are not in use.
    Anyway, thanks for your answer. Have a nice evening.
    BR
  • Craig Seeman
    July 9, 2009 at 6:23 pm
    [Günther Dilger] “Thanks, also this we found out now ourselves :-(. But in the manual it sounded like CH1 automatically forwards to both channels if internal and CH2 are not in use. “
    It should. When I use my Sony 680s in mono mode I plug in to channel 1 only and set CH1 internally and it sends to both.
