Activity › Forums › Adobe After Effects Expressions › mgJSON and timing of compositions
  • mgJSON and timing of compositions
    Posted by Otto Tasnadi on July 30, 2021 at 1:21 pm
    Hey, I saw here on this link (https://helpx.adobe.com/in/after-effects/using/data-driven-animations.html) that it might be possible to define the number of frames to offset (frameNumber) a layer from the start of the data layer specified from a “mgJSON” file
    1. Would this work with any other composition? (I am trying to find a solution to retime multiple compositions programmatically from a JSON file)
    2. How should exactly the mgJSON file look like? I am trying to write it but it just not working?
    3. Can I find anywhere documentation on this?
    4. If this is not the proper way to do it, then I should make it with scripting?
    If I understand it correctly, it is possible to control the start frame of a media file on the timeline from a Json file (more exactly from an mgJSON file).
    Does anybody have any knowledge in this direction?
    I can’t really figure it out what and how to do it… I have an mgJSON file like this, but it does not activate the Align the Video With Data
    “videoSyncTimeList”:
    “fileName”: “sample1.mp4”,
    “frameNumber”: 1000
    I actually want to control other composition’s timing. Is it Possible?
    Otto Tasnadi replied 5 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
