Activity › Forums › Adobe After Effects Expressions › metal plate wo 3dinv and like ps?
  • metal plate wo 3dinv and like ps?
    Posted by Wim Roegels on December 17, 2006 at 5:14 pm
    I jsut was wndering whether ist is possible to somehow ‘translate’ a tutorial of a meltel plate or text from photoshop to AE using just the standard tool set.
    Something like this …
    https://phong.com/tutorials/wire/
    Would be nice to get a little slow smooth movment in there, wouldn’t it?
    So far I was not able to find anything using the search, maybe someone around can point me into the right direction.
    Thanks.
    Best regards
    wim
    Mylenium replied 19 years, 9 months ago 2 Members · 2 Replies
  • Wim Roegels
    December 17, 2006 at 5:16 pm
    sorry for mixing up the letters that much
    me sutpdi
    Best regards
    wim
  • Mylenium
    December 17, 2006 at 7:01 pm
    You’d have to use the equivalent AE filters of course like Alpha Bevele and Drop Shadow. You’d also have to use multiple instances of those effects and multiple layers. Check my tutorial about creating shading effects here at the COW. Also, if you like, follow the link in my signature to my website and download the text styles. Though all the effects are applied to text layers, you can use them with any type of image as long as it has proper Alpha. since they are rigged with expressions, it should be easy to tweak them for your purposes.
    Mylenium
    [Pour Myl
