Activity › Forums › Maxon Cinema 4D › Metaball using particle emitter problems
  • Metaball using particle emitter problems
    Posted by John Hammond on April 16, 2009 at 10:56 am
    I am trying to set up a metaball object which uses a particle emitter as the source geometry. I have created a polygon object which contains just one point, and dropped it under my emitter as a child.
    Then I drop my emitter under my Metaball. And nothing happens! I can make it work using spheres as the particles, but I read somewhere that using points is best.
    Any ideas?
    John
    John Hammond replied 17 years, 5 months ago 3 Members · 4 Replies
  • Randy Johnson
    April 16, 2009 at 11:12 am
    Not sure what’s happening there… works for me.
    Polygon Primitive
    Make editable
    delete three points.
    Object manager looks like this:
    Metaball
    -Emitter
    –polygon
    Not sure why using a single point is better than a platonic though… maybe something to do with less points.
    /Randy
  • John Hammond
    April 16, 2009 at 11:34 am
    I have just tried your method using a polygon primitive, then deleting 3 points, and it works, so thank you!
    Before I was using Object/Polygon to create an empty polygon, and then I used Structure/Add Point to create a point. I read a tut somewhere that used this method. I don’t understand why it doesn’t work but your method does, so that’s great.
    John
  • Adam Trachtenberg
    April 16, 2009 at 2:32 pm
    I don’t think there’s any difference between using a sphere primitive (with “render perfect” enabled) and using a single point.
  • John Hammond
    April 16, 2009 at 2:41 pm
    Yes I think you are right,
    I’ve just done a quick test using points and spheres.
    They both had similar poly counts after metaball is applied. The only difference is that with a sphere you have a radius control which affects the metaball. With the point you have to add a metaball tag to adjust the ‘radius’ of each point.
    Once you make the sphere editable the metaball gets a lot bigger, so I suppose it is then using all points in the sphere’s geometry, where as when it is a primitive it treats it as a point with a radius. I think this is where I went wrong before.
    Thanks for the tips
    John
